Member postings for Big T
Here is a list of all the postings Big T has made in our forums. Click on a thread name to jump to the thread.
Thread: Autogyro Get togethers
08/09/2017 10:39:12
Posted by Piers Bowlan on 08/09/2017 08:33:41:
Hi Rich, There are three pusher models in one of the videos, they look rather like the full sized MTO sport or Caladus auto gyros (clue;-they are coloured yellow, Green and Pink respectively in the vid!). Are they foam and is there a plan yet? Just curious.
I think you are referring to Steve Jones Designs AC 20. There are free plans for download
Auto Skunkworks - AC20 EPP build
https://r.tapatalk.com/shareLink?share_fid=8309&share_tid=2340262&url=https%3A%2F%2Fwww%2Ercgroups%2Ecom%2Fforums%2Fshowthread%2Ephp%3Ft%3D2340262&share_type=t
https://www.rcgroups.com/forums/showthread.php?2340262-Auto-Skunkworks-AC20-EPP-build
Thread: Panther Trainer Autogyro
02/06/2016 10:31:36
HE 30 now called 6082.
02/06/2016 09:38:49
I get all of my alloy sheet and strip from http://www.mallardmetals.co.uk. He is a very friendly man, if you ring him and have a chat he will send you exactly the dimension you need. As far as a steerable tail wheel, in my opinion it's not needed, I just put in a skid. The rudder is plenty big enough to swing the tail and in any case you will need a more forward cg at first but that depends on the size of lipo, or are you going glow? BTW rumour has it that coolwinds have a limited supply of ready made blades in stock.
02/03/2016 14:37:05
Chiltern MFC Autogyro Fly In 2016
We are trying to fix a date for this years event. Our usual weekends in May clash with the Old Warden Mayfly and the Greeenacres events. We also have had an issue with our patch over the warm and wet winter which will could affect April and early May. So how does the first weekend in June sound?
Thread: Mr Tom Wright
26/01/2016 13:24:11
I have just heard the sad news that Tom Wright passed away yesterday 25th Jan 2016. Tom was one of those rare people who gave freely of his knowledge, had boundless enthusiasm for the world of model Autogyros and was a real gentleman in the true sense of the word.
I am sure that all those that had the pleasure of meeting Tom will miss him and the enthusiasm he brought to the hobby.
Thread: Ajay Autogyro
02/06/2015 10:30:02
I have an AJ for sale. It is one of the pre production kits that was used to test out various blades and set ups. Not pristine but in good flying order. I will sell with or without motor and servos. PM me if anyone is interested, if not its going on fleabay later this week.
Edited By Big T on 02/06/2015 10:30:21
Thread: AJAY Autogyro Build
30/09/2014 17:48:30
Well done Ray. Onward and Upward!!
Tim
30/09/2014 08:22:55
Hi Ray can you describe the vibration or better still post a video as it makes diagnosis simpler. If the blades are balanced correctly its Most likely the mounting bolts too loose or too tight. The way to test is to hold the model so the blade is parallel to the ground and give the model a downward shake. The blade should drop but not under its own weight. The other major source is the head assembled incorrectly as some are shipped from manufacturer very loose
29/09/2014 09:03:54
Yesterday I have the Tx to a couple of club members who had never flown gyros before just to test how the model performed with a true gyro Virgin. Given that the model is trimmed and sorted. I have to say that both did really well and found the AJ very satisfying to fly and both performed perfect landings and take offs. My caviat is that I taught both to fly and both learnt rudder control in the early stages.
24/09/2014 12:38:37
First test hops followed by a successful test flight yesterday. The wind was about 10 to 15 mph, a bit too strong if you have never flown a Gyro before. The flight characteristics of a gyro are effected in a big way by small adjustments so take your time and follow Tom's thread on first flight and trimming. As usual with Gyro's each one has it's own character, even if they are from the same litter, and this is no exception. The blades spin up very quickly and the head plate is soft enough to give a good "cone". What I did find was that as lifting rotation is achieved and the tail comes up I had to put in a small amount of back stick to get the nose up and lift off. Only a small bit, over do it and it will go vertical and you don't want that. On the next flight I decreased the down thrust on the motor by the thickness of a 1 new pence which reduced the effect. If a smaller prop or smaller motor is used then that would be the same as reducing down thrust. The rudder is very effective and ground handling is perfect. Full power in level flight is not needed, in fact you don't want to fly this model too fast or you will get some nasty handling as a result of the soft head plate making it very twitchy. Just remember that this is not a "bank and yank" model, try and keep the rotor flat in the turn by using all the controls.
It was easy to hold the model into wind and get into a steady hover with back stick, then reduce the power slowly until a perfect 3 point landing, just apply power at the end to keep rudder control.
On the 3rd and 4th flight I was soon cranking the rudder turns and touch and goes.
Final Settings
I ended up with a 3s 2200 all the way forward, Measured with the fuse floor as a datum: Trims at 9 degrees neutral back tilt, 2 degrees left roll and 4 degrees down thrust on the motor which had a 10 x 6e prop. Futaba -20 expo on aileron and elevator, nothing on rudder. End point on roll and elevator reduced to 50% . 14 degrees hang angle.
21/09/2014 18:09:17
SO here is the finished model ready to go
The layout of the battery and Rx. Stock motor with a 10 x 6 E prop pulls 30 amps at 330 watts at full throttle. AUW is 1.2kg so it should go OK. Neutral Trims are set to the listed figures in the manual for the test flight hops. I will set the throws to 100% and 50% on rates with - 10 expo on roll and pitch (- Futaba + for Spectrum). Forward pitch or down elevator will be reduced to prevent accidentally stopping the blades in flight.  Hang angle is about 14 degrees.
Final Comments On Build
The instructions are well written and clear, with the exception of the blades supports which where missing from my set of instructions. This will be corrected from now on. The materials and machining are superb and are exceptionally good value for money. Attention must be given to the HK head as they are supplied with non of the bolts tight, thread lock should be used.
Next post will be after the maiden.
Edited By Big T on 21/09/2014 18:10:27
21/09/2014 17:57:47
Posted by Tom Wright 2 on 20/09/2014 20:01:08:
Nice work Tim , my Ajay was a breeze to build and flew off the board with no fuss at all. Alan really has done a great job producing the kit.
Regards
Tom.
Hi Tom, I totally agree with both those statements. I maidend the proto and after a few trimming hops it was hands off take offs. Very easy in the turns both left and right providing the pilot used throttle, rudder and roll control correctly. Very tolerant of hang angle and stable in pitch.
One important pilots note for any experienced fixed wingers looking for a Gyro trainer, Gyro's do not respond well to "yank and bank" flying. The rudder and throttle are your primary controls, elevator is not how you climb but how you slow down. In many cases you will find yourself giving opposite roll to yaw and throttle to maintain height.
19/09/2014 15:29:13
I have now moved onto the covering of the model. As this is a trainer it is most important that the nose and tail are easily identified in flight. ALL model gyro pilots get disoriented in a turn at some time or other. One of the key helps its if the tail stands out from the nose. Don't worry too much about the blades as you normally don't look at then in flight. Once you get used to them spinning at the correct speed for flight, that's all you need. Usually if you get to see the top of the blade in flight it's all over anyway! SO I have chosen an easy to do colour scheme of white iron on film for the spine, silver paint for the ply floor and bulkhead and a floro yellow for the side strakes. The tail is in the same checker film as the blades. So while I wait for the motor to arrive I am going to get on with that.
19/09/2014 15:21:46
Then using the top plate hole as a guide drill a hole through the complete assembly and cover using your favorite method. I used HobbyKing heat shrink film but you could use a thin adhesive sticky back plastic or even reinforced parcel tape.
I then balance each bladed length ways to establish the CofG. You can see the pencil mark on the blades in the picture below. If the centre's are a long way of then add tape the root end to get them together. As you can see these are very close without any adjustment at all.
I then pair up the blades and balance them until they are all the same. If needed you add tape to the CofG of the lighter blade. This is important if you want to have a smooth Gyro. Some might skip this bit but it pays to be thorough. The blades can then be mounted on the head plate with the supplied cap bolts. Do not over tighten the bolts. The correct tension is just so that the blade can move with a small amount of friction holding them in place. Too tight and they will "hunt" shaking the plane in flight. Too loose and they will not track correctly.
Edited By Big T on 17/09/2014 09:04:43
19/09/2014 07:54:34
STOP PRESS
I have mounted the lower blades supports incorrectly. The next sequence will show the correct method.
17/09/2014 09:06:55
Next I will mount the motor, Rx, ESC, battery, do the radio mixes and throws as per the instructions. Then break it all down and cover the model. My choice will be to film the spline, tailplane and rudder and paint the floor , bulkhead and tray.
17/09/2014 08:40:14
Blades
The blades are the usual excellent AJ Blades product. For those of you who may be put off from trying a Gyro due to the complexity of making and balancing blades then this is the answer. In fact many of the "die hard's" who made their own in the past now use blades from these guy's. Preparation starts with determining the span wise CogG. Just follow the supplied instruction's or refer to Rich Harris's You Tube video if you are unsure how to do this. After determining the CofG, glue the top GRP reinforcing plate in place, I use cyno for this. Now, very important for everyone, even you experts, make sure you stick this on the ROOT end not the TIP. Remember the blades rotate Anti Clock!!!
The lower GRP brace is then glued as shown below.
16/09/2014 15:03:32
I have to admit to making an error of measurement here! The instructions give the dimension of 17mm for the center of the tiller. Please note that this is from the top of the nylon mount not from the bottom of the rudder. This is why the GRP doubler on mine was not level with the bottom of the rudder.
This picture shows the route of the rudder push rod which has a double offset. Remember to put the guide tube on the rod before bending!
The Head
Take the rotor head and remove the blade mounts reserving the nuts and bolts. Assemble the supplied AJ GRP blade plate onto the spindle carrier. Make sure that you get it the right way up as the blade mounting holes are offset to give an easier mounting of the shims. The unit is supplied by the manufacturer with all the nuts and bolts loose so make sure that you nip them all up and use a light thread lock. The rotor spindle assembly is mounted onto the rotor shaft. The mount needs shimming onto the shaft with sections of the blade shim.
Note the blade mounting holes offset
Pushrod mounted into the keeper on the servo and cut to length.
15/09/2014 13:00:04
15/09/2014 12:52:51
Before I move on to the next stage I would like to compliment AJ on the quality of this kit. The quality of the wood, accessories and production of parts is better than anything I have experienced. The design is an easy build for a novice builder and challenging enough for a first plan builder. Frankly I don't know how they do it for the money.
_____________________________________________________________________________________________
So, onto fixing the servo rails and mounting blocks. These pictures say it better than words.
This is the 2 hard wood blocks that also form the mounts for the false floor. Then using your servos as spacers you fix the second and 3rd rails in line. Then the mounting blocks for the servos to screw into.
The rudder servo took a small head scratch and beard pull to work out but it is very simple in fact.
There is a slotted bearer and solid bearer. The slot is to enable you to screw the servo onto the bearer.
All beares in and the false floor fitted. The false floor is even cut with the motor thrust taken into account!
Next we fit the side rails and cut out the access for the servos.
Servos fitted and linkage installed with supplied hardware.
Tail wheel assembly which is assembled as per the instructions and stuck to the recess with epoxy.
The tailplane is made up of 3 components which glue together with your favourite adhesive. The fin and rudder are assembled as per instructions. At this point I chose to change the mounting of the tiller arm as I have a particular way to do it. I chose to mount the rudder to the fin using the Fuzzy Hinges supplied in the kit, then mount the rudder onto the tail plane, then mount the assembly onto the fuselage and get this perfectly lined up and square. I then stuck one of the GRP plates onto the rudder in the location of the "tiller". I then marked the tiller onto the rudder and cut a slot in the balsa through to the GRP. Then I slotted in the tiller and glued the opposite GRP plase in place. I then drilled and mounted the Horn which is supplied with 2 cap bolts and nuts. Another lovely touch.
Latest Forum Posts
Support Our Partners
electricwingman 2017
CML
Sussex Model Centre
Slec
Sarik
Advertise With Us
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
