Member postings for Terry Whiting 1
Here is a list of all the postings Terry Whiting 1 has made in our forums. Click on a thread name to jump to the thread.
Thread: The Atom Special
20/04/2015 13:09:49
David when I zoomed into your attachment it didn't look positively sharp if I was wrong I apologize, but it's certainly worth adding more shim.. Strips of 1/64" birch ply can be used, it does't have to be FG sheet.
20/04/2015 07:50:49
David,
As Steve stated no rounding of the LE. Reason being any rounding induces a certain amount of positive incidence to the blade, If I had the same problem I would add extra 0.04m shims in increments until I eliminated the nose up climb out......worth a try
Terry.
19/04/2015 07:05:21
David,
Have you by chance rounded the LE of your blades as the finished profile should look as this ..... Terry.000_0147.jpg
10/04/2015 07:18:11
Chris, You are right and I was right first time,.............. going gar gar, had a senior moment, blush
09/04/2015 19:09:32
Sorry Chris,....meant VLOblush
Edited By Terry Whiting 1 on 09/04/2015 19:10:04
09/04/2015 15:56:23
Chris & Frank,,
Two really good videos, and as for that take off Chris it was almost a VTO yes
03/04/2015 15:18:56
Hi All,
I had another couple sets of blades to balance and came up with this idea which I found dead easy in finding the chord balance. . It's an odd piece of anodized of aluminium angle I had, I stated anodized because I found the edges were rounded where as un-anodized were finished square.000_0167.jpg.000_0166.jpg.000_0168.jpg I found it far easier than the pin method,
Terry
30/03/2015 15:20:50
All three look very nice Orgur, model, site and weather yes
Terry
25/03/2015 06:41:12
Frank,
That was a really impressive flight, yes If I can manage my first flight half as good as yours I will be chuffed to bits..
Terry
16/03/2015 17:13:10
Wise words from Steve and Max......that makes perfect sense .
.thanks
Terry
13/03/2015 19:37:41
Hi John,
There's no problem using a strip of 1/64" , after all it's still doing same job giving the blade neg incidence.. just make sure it's positioned at the recommended measurement.
11/03/2015 06:45:44
Rich,
Photos go ahead, I regard it as a complement wink
07/03/2015 07:35:23
Hi Kevin,
A very nice looking model. Good to see you back at Gyro building, hope you are keeping well..
Terry
28/02/2015 07:16:32
Hi Max,
That makes sense, I will recover after the weekend.
Cheersyes
Terry
27/02/2015 17:21:48
Max
Thanks for your advise on the upper surface blade colour. I opted for gold yellow underside and dark blue tops thinking it would help visually whether it was flying away from me or towards me. If this doesn't work out as planned I will recover..
I also took on board your comment  on turning with use of the rudder, this was going to be my approach .
Thanks again.
Terry
Edited By Terry Whiting 1 on 27/02/2015 17:22:52
Edited By Terry Whiting 1 on 27/02/2015 17:30:43
Thread: Completed Atom photo gallery
24/02/2015 11:13:39
Mine hasn't been airborne as yet as our patch will not be ready until the end of March.000_0159.jpg
10/02/2015 19:58:46
Chas that looks the business. Strangely enough I was going to call in Old Warden today after calling into
GM Growers, but time wasn't on my side sad
Terry
10/02/2015 16:45:12
Hi Ozgur,
I don''t know if you were directing your question to Rich or to any one in this build., but I can assure you D1 sets the required mast angle.
I wish you all the best with your build.
Terry .
07/02/2015 17:07:16
Rich,
Our club field will not be flyable until spring, water being the main problem , and me being in my 80's I do like a bit of sun on my back these days wink ......sadly gone have the days being an all weather flyer .
Terry
07/02/2015 11:20:33
000_0159.jpgAs Malcolm of Coolwinds is local to me and I saw on his site he produces vinyl graphics I thought I would ask him if he could knock me up a set for the Atom and as you can see he kindly obliged. I must say it gives the finishing touch the Atom deserves
Latest Forum Posts
Support Our Partners
Sussex Model Centre
CML
electricwingman 2017
Slec
Advertise With Us
Sarik
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
