Member postings for RC Plane Flyer
Here is a list of all the postings RC Plane Flyer has made in our forums. Click on a thread name to jump to the thread.
Thread: Antics online / WOT 4 MkII E (balsa)
08/03/2013 13:16:02
Hi M -- Just been in hanger and confirm I fly at 90mm CoG without any problem
If I fly in breezy conditionsit is possible to land like a Helicopter thingy
08/03/2013 08:26:52
Hi M --- Ripmax advised some motor which was expensive so I searched around and found a similar rated motor at 400 watts Fusion Logic and went for a 50Amp plus ecs using 2700 lipos I have plenty 8 mins flights per battery  with power to spare no lead required
Edited By RC Plane Flyer on 08/03/2013 08:38:09
07/03/2013 17:35:20
Hi there M One piece of advice have a look at strengthening around the fusalage base where the undercarriage fits ( Triangular stock with epoxy or lite ply fillets up the sides and touching the bulk head or a good soak with glass cloths resin ) Happy flying and landings
Thread: Weekend Giveaway
01/03/2013 08:50:59
Books or glue for me so i can read when i cannot fly
Thread: Prop rpm
16/02/2013 15:52:00
Hello Keith Try DarBroRC Models Turnigy Unit phone on 01270 879101
It will have to be a phone call as they are modifiying there web pages somwhere around £13 inc postage
Thread: New SC46 - Running issue
27/01/2013 15:36:11
Hi Tony if you can obtain a Taylor Glow plug with idle bar you will suprised how much a smooth pick up should be
Thread: engine care
27/01/2013 15:32:37
Hello Keith
You wont go wrong with the 3 in one Oil down the carb and plug area just make sure you turn the engines over to check no Hydraulic Lock up
Thread: Change old switch harness
23/01/2013 14:33:29
Originally it was thought that fast charging batteries in the plane through the wiring harness was problamatic say over 1 amp or greater as a quick charge at the flying field.
Slow charge in the Hanger when back home was not a problem ??
Thread: ASP46 2-stroke - a couple of questions on what I should do
22/01/2013 13:44:30
Have you looked at Just Engines or other suppliers for the ASP Short Engine option ?? Use your own Carb & Silencer
Thread: Stop cord fraying
21/01/2013 13:24:18
Another tip is to pull  the thread over some bees wax or at worst a candle to enable a smooth run through the holes in the spars
Edited By RC Plane Flyer on 21/01/2013 13:25:37
Thread: Changing email address
11/01/2013 16:26:51
My windows 8 tools bar is not as easy to follow as my XP system Have reset password etc and getting in easier Many Thanks for your messages
11/01/2013 10:10:00
I am Windows 8 ( New Laptop after 7 years ) and still amased at what it does automattically
11/01/2013 10:06:23
Not same problem but some how my screen has remembered an incorrect spelling of my e mail and password. if i type in my correct e mail and password i am unable to log in so i have to use the incorrect email address amend it and i can log in ?? Question is can I clear the the error and start again I Have tried various things in my account but not resolved it as yet Many thanks if i get assistance
Thread: Electric newby starting a Wot4 E and requiring advice please
04/01/2013 09:47:29
Hi OP whoops should have read the thread start to finish, trust my last sentence may help Keith
Edited By RC Plane Flyer on 04/01/2013 09:49:27
04/01/2013 09:14:44
I would suggest a basic start point of 350 watt motor prop to match motor and 50 amp speed control and 2700 3 s liipos and some Hitec hs82 metal gear servos along with your radio . If possible show your loaction and see if your local club has a flyer with one to look see and watch
Thread: Just Engines JEN range
02/01/2013 09:26:34
They are a good engine once set from new just two minor points to be aware of The bottom end jet more than likely will need a minor tweek to get decent smooth tickover, double check around the carb to engine area eg the pinch bolt for air leaks. I have fitted an o ring under the carb to eliminate this
Thread: Attaching Servos - tape?
29/12/2012 16:50:44
Hi There I have used the double sided pads that are used for Interior rear view mirrors. My local car parts shops charges 30p each
Thread: Friday free stuff
23/11/2012 10:21:40
Yes please I am In
Thread: Hitec Optic 6 Transmitter On / Off Switch
11/11/2012 14:42:19
Hello out there today my Optic 6 started giving me problems when I switched it off the screen showed low battery and bleeping. I switched on and off again and same thing and the blue on light was glowing. I have gone through all the tests with alternative fully charge battery and still same problem. any suggestions or am I to look at Xmas list. I will try Hitec Support but asking just in case
Thread: Merco 61 cleaning the brown stuff off
23/10/2012 14:30:17
Maybe try Fairy Power Spray from under the kitchen sink
Keep a check on its actions and then remove with an old tooth brush
Latest Forum Posts
Support Our Partners
electricwingman 2017
CML
Slec
Sussex Model Centre
Advertise With Us
Sarik
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
