Member postings for RC Plane Flyer
Here is a list of all the postings RC Plane Flyer has made in our forums. Click on a thread name to jump to the thread.
Thread: RCM&E Vector March 2016 free plan
06/10/2019 16:35:17
Don't Know what went wrong but the Vector Album has gone to no mans land for now
06/10/2019 15:39:40
A little Update Majority of Balsa purchased yesterday and made a start on wing panel template last night. Made two wing panels this morning along with WR piece. Tried doing a build blog but photos all over place so they are in an Album. Would be interested in tips on how to feather the wing down I have a razor plane and sanding blocks but this looks time consuming. I have a belt sander and thinking of fixing to bench and taking majority of wood away before final finishing by hand
04/10/2019 19:52:25
So taken the plunge and ordered a motor rated at 1400kV around 200 watts as is mentioned in Mag .
Looks like a trip to Leeds Model Shop for some balsa tomorrow need to make a basic list out later they have some 4"wide listed
Lets see what happens
04/10/2019 15:27:15
Not gone away still looking for a suitable motor. Just E Mailed George at 4 Max
Have found a DYS 2812 1200kV rated upto 200 watts
Should I be looking for a higher reving motor ?
01/10/2019 20:23:14
I like the look of the Mini Blitz as an alternative in your photo album
01/10/2019 11:13:51
So having read the thread three times checked the plan etc three times read the mag three times just been in hanger to double check motor spec and its not going to happen. My motor is 1150 Kv and needs at least 9" prop to deliver 1100 grams thrust
30/09/2019 12:28:50
Just clearing some mags out in hanger and came across this one . Looks like it's the next model for me may take a month or so due to other commitments
Thread: What replacement for brushed
12/09/2019 19:05:29
Could I suggest a call to George at 4 max the maybe able to suggest something
Thread: Cyclon 2v cells
07/09/2019 13:24:03
Hi FB 3 An option could be a 1.2 volt 4 amp/hr NiMh cell used one for years and never failed to start an engine
Thread: Drone At Gatwick
28/08/2019 13:55:56
WHOOPS sorry did not see further down pages it was about the incident on 28th April
Must book and appointment at Opticians ASAP
28/08/2019 13:01:11
I see its happened again
Drone at 520 Mts   and inside restricted area cause Air Bus to divert
186 people plus cabin crew etc  at risk
Edited By RC Plane Flyer on 28/08/2019 13:18:24
Thread: Broken servo arm screw
27/08/2019 21:20:22
Some 12 months ago I bought a second hand Seagull Harrier that someone had converted to electric and had fitted Corona midi servos. Unfortunately I found out that out of the five fitted in various areas they had all broken on the flange where the screws held them in place. Not sure if it was mishandling or a bit of UV making them brittle in this area
Thread: Acro Wot Alternative
27/08/2019 20:57:22
I lost my 6 year old ARTF Acro Wot a month ago and searched the internet but none available for last 12 month. My alternative would have been various Seagull brands ( Airtek Hobbies seem to have some stock ) last alternative was the Kyosho Calamato the one with better covering . I had numerous 46 two strokes available and finished up with an ARTF Wot 4 to replace my aging one and that must have been one of the latter ones available
Happy Searching
Thread: Possibly going all electric, which motors should I use?
25/08/2019 12:20:50
I have to agree with Nigel R. I get more fun out of a £19 gallon of Laser fuel than an equivilant lipo battery
It is horses for courses and we all have our own opinion
I do have an Easy Street and electric pylon racer both fun to fly but time restricted
Thread: O S
21/08/2019 14:11:34
Maurice just click on 4724 forum post under Jons name
Thread: Balsa skin on wing
16/08/2019 19:02:23
I once built a french model glider that needed curved ribs skinning and the tip was to get all set, glue up ribs cover with balsa and cover the balsa with something like RCME Magazines or other similar magazines that followed the curves perfectly weighing down the balsa
Thread: Single servo ailerons
16/08/2019 14:15:51
I am reading all the responces thank you all. Appreciate I did have a control set up slightly higher than should be without my usual expo set up for my flying routines.
And without going off on another tangent is more up than down a better set up with a single or two servo set up ?
I have over 20 plus years building and flying IC models and tamed them all but this one is not to my liking as yet
Thanks again for all your inputs
15/08/2019 07:26:47
Wow what have I done I was only asking if I was to mod my servo horn to give more up than down was that the correct way? As is said in other topics ask 6 modelers this question you get 8 options.
Thanks to all who have responded on my aileron question. At present I have found my original circular horn for futaba servos but have hirec servo fitted.
I am going to reset the settings back to plan recommendations 3/16 to 1/4 on see how we go. as said earlier some how I was at 5/16 with no expo to soften the sticks
14/08/2019 11:39:43
Just in case I did not make myself clear I think this kit was built some 8+years ago with a modeller who followed the plans. So it came with the single servo option and torque rods fitted I have a feeling with the finish it was covered in balsaloc and then some heavy duty covering.  My start point on expo is -30% and then I go up or down to suit the model characteristics and my style of flying
Happy days when I get this one trimmed out
Edited By RC Plane Flyer on 14/08/2019 11:44:51
14/08/2019 09:21:39
Looking at the size of the airelons on the wing I think a mini servos may struggle under load I have two midi servos in the workshop that would do the job just need to check the output specifications
Latest Forum Posts
Support Our Partners
electricwingman 2017
CML
Slec
Sussex Model Centre
Advertise With Us
Sarik
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
