Member postings for Graham R
Here is a list of all the postings Graham R has made in our forums. Click on a thread name to jump to the thread.
Thread: Binding and updating
17/01/2017 10:15:25
Morning all,
A darkened room was certainly needed. Spent some time on Sunday going through some of my receivers and also getting reaqainted with the Taranis. So far I have only 1 rx that won't bind - X6R. I guess that this one needs a change of firmware.
Graham
Thread: Who wants a Warbird Replics Hurricane?
15/01/2017 12:11:14
Posted by Jon Harper - Laser Engines on 15/01/2017 10:53:36:
Posted by Graham Russell on 15/01/2017 10:00:32:
I am withdrawing my interest in the Hurricane (my favourite) and have gone with the ME110. Hard decision but I have recently bought the Mk9 Spitfire. This will be my 1st ever twin( in 40+ years of modelling.
Twins are different but not difficult. once the kits are in hand we will get a thread going with setup tips etc. will yours make a noise?
Hi Jon,
Mine is going to be electric. Are you going for one, and if you are I look forward to the thread.
15/01/2017 10:00:32
11/01/2017 21:52:03
Hi Chris,
Will do. Thanks once again
Graham
11/01/2017 20:48:12
Good evening all,
Having got back a working Tx with a basic setup what's next?
Do I need to build a load that includes Eu and the other bits I left off.
I haven't tried any of my receivers yet
Graham
11/01/2017 20:13:21
The hurricane was my 1st choice but I had the Spitfire instead as there was no Hurries in stock. If it's not going to be for a couple of months I would have one. They can be electric I hope.
Edited By Graham Russell on 11/01/2017 20:17:24
10/01/2017 22:07:43
Doh Doh Dohblush
Just switched on after a little charge, system now working. With All this trying out over the last few days I have drained the battery. (because system not working, I was not able to see the battery status).
Tonight it will have a good charge. After that - sort out the original problem - eu or non eu , receivers etc.
Thanks to everybody for your time spent so farbeer, very much appreciated.
10/01/2017 20:41:10
Ah good point andy. because of no display I can't ee battery condition going to put it on charge now
10/01/2017 20:35:24
I'm sorry Andy, what I am trying to say is that the Tx dies after selecting write. It never gets to the next screen.
If I wait a few seconds before I select Write, the Tx dies.
Graham
10/01/2017 20:18:55
Andy - boot loader is ver 2.0.12
Peter I did that the 1st time but now when I switch on and if I'm lucky I get that screen display and I select write - the screen goes blank and the machine gunnies starts. thats all that happens until I switch off.
10/01/2017 19:59:49
I did that Andy.
If I switch on now with trims l/r
display - writefw start up screen
displays file name.
if I don't do anything, after about 10secs screen goes blank then noise starts
I then power off disconnect battery reconnect battery switch on - nothing except noise
10/01/2017 19:47:46
Chris.
I'm not getting that message any more since installing dry-util.
everything seems to go ok without errors.
it's just that there is nothing there except the noise
Graham
10/01/2017 19:40:15
I have created a very basic build as suggested
I tried installing via sd card Trims l/r etc.
write firmware Displays correct file name press enter dispels writing etc.
power off then on displays opentx very briefly then starts m/c gun noise.
Then tried with opentx. all appears ok . power off then on - same result nothing but constant noise.
10/01/2017 18:49:49
Hi Pete
Loaded the SD card into the Mac card reader. Created a directory called FIRMWARES and copied a file called
'open-taranis-no-heli-massstorage-mixersmon-en.bin into it.
​Replaced the sd card back into Tx switched on with trims set
selected 'write firmware' for some reason it displayed 2 file names even tho only 1 in directory
​pressed enter and now as reported
I have tried booting without SD - only get the generated noise
Graham
10/01/2017 18:33:10
Think I have got a bit fed up with my Taranisangry
10/01/2017 18:27:31
Hi Chris
I think my Taranis must have died. Just did as you suggested , it started loading some software and now all that happens is the speaker sounds like a machine gun and nothing else happens.
10/01/2017 18:13:04
Andy, found path setting in "set up communications" path is now set correctly.
tried write firmware to tx. error message "new f/w not compatible with one currently installed" back again.
10/01/2017 17:55:37
sorry Andy, Just downloaded dfu-util and installed.
can't find the burn prefs in companion
10/01/2017 17:23:49
Thanks Chris
10/01/2017 17:13:44
Done that and it reports ' directory missing"
directories on sd card are bmp, docs.firmware, models, sounds, videos, logs, eeproms
and files sadie_xp.exe and sadie.exe (probably left over when i had a pc)
and companion9xinstall_vt1.32.exe
Latest Forum Posts
Support Our Partners
Slec
electricwingman 2017
CML
Sussex Model Centre
Sarik
Advertise With Us
Latest "For Sale" Ads
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
