Member postings for Graham R
Here is a list of all the postings Graham R has made in our forums. Click on a thread name to jump to the thread.
Thread: Warbird Replicas Bf 109 club.
17/02/2018 19:43:13
All is now sorted, fuz all glued up (with wing bolt plate up the right way).Phots to follow. Thank you all The Hirobos are on me.
15/02/2018 22:40:54
Half eaten Haribo!!!!! You were lucky. Those boys of Richard are getting careless.
15/02/2018 20:22:09
Thanks for the info Paul.
I used the rear foam block as the datum and aligned all the top mouldings to it. I wasn't sure whether it was the ply crutch or the foam pieces which caused the problem. I was surprised how much foam I had to remove from the bottom of the foam moulding to accommodate the ply crutch assembly. I will take the ply crutch as gospel and adjust the foam wing seat.
15/02/2018 18:22:32
Cockpit.jpegfront.jpegSuggestions needed. Having problems with the ply crutch not lining up with the wing cutouts on the foam cheeks. Everything else seems to line up ok. Pictures show the problem. Any suggestions will be greatly appreciated.
15/02/2018 11:40:02
Hi Paul, I am being a bit thick. I’m not quite sure what you mean by “pushed out first.
If I push the crutch side into the rear foam then the wing plate will not quite be log enough to straddle the two sides.(see 1st picture.
One other question, the gap at the bottom of the rear foam block. Is it filled with balsa or are the two sides clamped together and glued.
Thanks for your and David’s help.
14/02/2018 16:23:20
Has anybody else found that the cutouts in the foam panels are a little bit big and so glueing to the plywood crutch is not possible without packing. 498ed02d-4a39-4eaf-8d72-2947f0b65c3d.jpeg
01/02/2018 22:44:38
Haribos certainly help when building.
Thread: Cornish Beaches with DJI Spark
01/02/2018 17:19:47
Never seen a Cornish beach so deserted! Nice
01/02/2018 16:43:25
I have at last opened the box and started to look at the rudder assembly. Does the rudder post need l/e need to be tapered in to meet the ribs before adding strip as in picture?
Thread: Warbird Replicas Bf 110 club.
25/01/2018 21:33:07
Glad to hear all is going well. My wife was allowed to drive 6 weeks after the op.
Thanks for sorting out supplies,info etc. thats exactly what I was after. No point trying to re invent the wheel along with repeating the same mistakes.
25/01/2018 09:07:05
Hi Nigel, How is the recovery going? Ready for a marathon yetlaugh
I like your tail wheel bracket. I would be interested in knowing how you made it (in easy steps along with materials. (For another project).
Sussex Graham
22/01/2018 23:04:35
Hi Paul, sorry to have left you leading the way for us on the 109 build. I have been busy trying to finish refurbishing a few of the old models before starting a new project.
i hope to be starting mine within the next few weeks. I wonder how DD is getting on with his.
14/01/2018 10:08:55
Morning Paul,
I have re read the thread but I thought that I would see if there were any other ideas. I to have a wonderful set of resin stacks, which I seem to think you had something to do with.
With mine I have even opened out the pipes with a dremel. Took a while but the effect is good. Just got to find a way of giving them a scale colouring.
Ps. Now that I have paid for my 109 I can now start to have a look at the 109 while I am waiting for the weather to improve so the I can start spraying.
I expect that I will be asking you a few questions on that thread also.
Edited By Graham R on 14/01/2018 10:12:56
Thread: Aeronca Sedan
14/01/2018 10:01:29
Posted by Erfolg on 11/01/2018 16:40:38:
I am pretty much decided that a more fashionable airfoil will be used. Principally just because these older kits I have built seem to be more a one speed affair, without a lot of power being used.
You are absolutely correct with the flying characteristics. The one in our club as mentioned before is some 120%(wingspan is around 78" 3 channel. Flies on a 2820/10 with very little throttle. Perhaps that is the charm of this great model.
14/01/2018 09:49:57
Hi all,
Just thought I would dust the cobwebs off this thread.
Any conclusions as to the best way of dealing with the exhaust stacks on the bf110?
09/01/2018 18:08:13
We have one flying in our club. It has been enlarged to around 120%. It flies very well with a small brushless motor. I’m very interested in your build especially the fitting of aeilerons as I have the plan sitting on my todo list.
07/01/2018 19:26:18
Hi Paul, have I missed something? Just wondering why you're showing how to reverse a servo?
27/12/2017 21:11:57
Hi Paul,
I have had a good look inside the box. looks good and looking forward to starting it. reading through the instruction book, just a little concerned with the comments about it's behaviour on takeoff i.e it's inability to track straight, still thats for the future.
Thread: Changing connectors on my Lipo batteries
22/12/2017 17:56:56
Out of interest what do you find unsafe about xt60’s. I changed over to them from 4mm bullet connectors as I found them to be unsafe (male pins only protected by fuel tubing).
Edited By Graham R on 22/12/2017 17:57:40
21/12/2017 09:45:54
Potatoes and an orange - you were lucky, all we had were potato peelings and cold water! And they were raw. (I feel a sketch coming on here)
Edited By Graham R on 21/12/2017 09:48:35
Latest Forum Posts
Support Our Partners
Slec
CML
electricwingman 2017
Sussex Model Centre
Advertise With Us
Sarik
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
