Here is a list of all the postings Graham R has made in our forums. Click on a thread name to jump to the thread.
Thread: Warbird Replicas Bf 109 club. |
23/02/2018 20:41:40 |
Hi Paul, quick question, the ply tailplane supports, do they fit between the foam and the crutch or on the inside of the crutch. Have built the elevators, ruder and fin, not able to complete the tailplane as no balsa sheeting was supplied and am waiting for a delivery from Balsa Cabin. Started trimming supercharger moulding, finding it quite fiddly as no outline marking visible. Your exhaust shield - nice touch. |
18/02/2018 22:45:14 |
Had a look through all the bags, but I don’t seem to have any wire for the tail wheel. It is a pre-shaped item or just a piano rod piece. Edited By Graham R on 18/02/2018 22:45:49 |
18/02/2018 18:09:45 |
Posted by McG 6969 on 17/02/2018 14:28:00:
Posted by Graham R on 15/02/2018 18:22:32:
Suggestions needed. Having problems with the ply crutch not lining up with the wing cutouts on the foam cheeks. Everything else seems to line up ok. Pictures show the problem. Any suggestions will be greatly appreciated.
Hi Graham, I realize that I should mind my own business of course, but if the extra width of foam is where the wing joins to the fuse, could it then be that your blind nut is on the wrong side of the beam??? Cheers Chris
Hi Chris, No problem, that's the reason we publish our work on here -to instruct and also to attract help and ideas. Graham |
18/02/2018 11:17:03 |
Hi Paul, 109 is looking good. Won't be long now until we can get spraying the 110's. |
Thread: Best Plane You Have Owned |
17/02/2018 23:00:42 |
Skyway bae Hawk - flew on rails Skyway hawk 70 - viceless Junior 60 - fun and relaxing |
17/02/2018 19:43:13 |
All is now sorted, fuz all glued up (with wing bolt plate up the right way).Phots to follow. Thank you all The Hirobos are on me. |
15/02/2018 22:40:54 |
Half eaten Haribo!!!!! You were lucky. Those boys of Richard are getting careless. |
15/02/2018 20:22:09 |
Thanks for the info Paul. I used the rear foam block as the datum and aligned all the top mouldings to it. I wasn't sure whether it was the ply crutch or the foam pieces which caused the problem. I was surprised how much foam I had to remove from the bottom of the foam moulding to accommodate the ply crutch assembly. I will take the ply crutch as gospel and adjust the foam wing seat. |
15/02/2018 18:22:32 |
15/02/2018 11:40:02 |
Hi Paul, I am being a bit thick. I’m not quite sure what you mean by “pushed out first. If I push the crutch side into the rear foam then the wing plate will not quite be log enough to straddle the two sides.(see 1st picture. One other question, the gap at the bottom of the rear foam block. Is it filled with balsa or are the two sides clamped together and glued. Thanks for your and David’s help. |
14/02/2018 16:23:20 |
Has anybody else found that the cutouts in the foam panels are a little bit big and so glueing to the plywood crutch is not possible without packing. |
01/02/2018 22:44:38 |
Haribos certainly help when building. |
Thread: Cornish Beaches with DJI Spark |
01/02/2018 17:19:47 |
Never seen a Cornish beach so deserted! Nice |
01/02/2018 16:43:25 |
I have at last opened the box and started to look at the rudder assembly. Does the rudder post need l/e need to be tapered in to meet the ribs before adding strip as in picture? |
Thread: Warbird Replicas Bf 110 club. |
25/01/2018 21:33:07 |
Glad to hear all is going well. My wife was allowed to drive 6 weeks after the op. Thanks for sorting out supplies,info etc. thats exactly what I was after. No point trying to re invent the wheel along with repeating the same mistakes. |
25/01/2018 09:07:05 |
Hi Nigel, How is the recovery going? Ready for a marathon yet I like your tail wheel bracket. I would be interested in knowing how you made it (in easy steps along with materials. (For another project). Sussex Graham |
22/01/2018 23:04:35 |
Hi Paul, sorry to have left you leading the way for us on the 109 build. I have been busy trying to finish refurbishing a few of the old models before starting a new project. i hope to be starting mine within the next few weeks. I wonder how DD is getting on with his. |
14/01/2018 10:08:55 |
Morning Paul, I have re read the thread but I thought that I would see if there were any other ideas. I to have a wonderful set of resin stacks, which I seem to think you had something to do with. With mine I have even opened out the pipes with a dremel. Took a while but the effect is good. Just got to find a way of giving them a scale colouring. Ps. Now that I have paid for my 109 I can now start to have a look at the 109 while I am waiting for the weather to improve so the I can start spraying. I expect that I will be asking you a few questions on that thread also. Edited By Graham R on 14/01/2018 10:12:56 |
Thread: Aeronca Sedan |
14/01/2018 10:01:29 |
Posted by Erfolg on 11/01/2018 16:40:38:
I am pretty much decided that a more fashionable airfoil will be used. Principally just because these older kits I have built seem to be more a one speed affair, without a lot of power being used. You are absolutely correct with the flying characteristics. The one in our club as mentioned before is some 120%(wingspan is around 78" |
14/01/2018 09:49:57 |
Hi all, Just thought I would dust the cobwebs off this thread. Any conclusions as to the best way of dealing with the exhaust stacks on the bf110? |
