Forum sponsored by:
Forum sponsored by CML
Infinity 90 Build
How good is it ?
All Topics | Latest Posts
Search for:  in Thread Title in
cymaz09/01/2019 22:31:15
avatar
9249 forum posts
1194 photos
Arrived home today to find a 6’ box in the porch. I put on the delivery instructions “leave with neighbours “. I assume one of the neighbours brought it over.....if not, just as well we live in a quiet, secluded cul-de-sac.
Right, first things first, get the box open.....if anyone has seen AVE on YouTube then you know of his modus operandi in getting into new items. Not me, gently does it just in case anything is missed.
There is a lot of packing, I mean it, a lot..
Everything is held well down with tape and wrapped in foam.
So let’s dig further. Hardware pack. The tank will not be used. I’m putting in a 20cc petrol engine. There is no mention of petrol engines in the manual so I won’t trust the fuel bung, pipes etc.
There are some things that bug me on a £300 airframe. Cheap, nasty foam wheels. The bolts that are threaded into the control horns do not have securing nuts. These will all be changed to proper nuts and bolts.
cymaz09/01/2019 22:35:47
avatar
9249 forum posts
1194 photos
Build quality and glue amounts look good.
Tank bay, servo area
There is no mention of this hatch in the rear of the fuselage,
Excellent colour schemes
cymaz09/01/2019 22:46:31
avatar
9249 forum posts
1194 photos
There are some areas that are not really good.
The tail has no glue area whatsoever! I will need to glue a ply plate into the fuselage. Can’t have the elevators coming loose...the fit is not tight either.
I’m not sure how the engine is suppose to bolt in here with only two holes for the fixing mount? Some serious bracing and fuel proofing needed here. The undercarriage fixing plate is a good 1/4” ply. Glue quality is probably not is good as it could be...triangular bracing and epoxy will be added.
The top of the cowl does not come off. Exacerbating the difficulty of motor installation....we will see
cymaz09/01/2019 22:48:20
avatar
9249 forum posts
1194 photos
Nice big hard point in the moving surfaces,
Peter Jenkins09/01/2019 23:48:49
1596 forum posts
264 photos
Following! Remember, wheels need to be light for aerobatic aircraft which is why the provide these light weight ones.
Bruce Collinson10/01/2019 08:56:41
532 forum posts
C,
Looks a dead ringer for mine. My clubmate's has arrived too and I'm hoping to see him later to scrounge the manual. He has already hit the buffers with the quiet mounts, which are woefully short for a Laser 100. I ditched mine and bolted a U-shaped ply plate to the original sub-plate.
Looks like the forward mount fasteners may have been missed out, or are they to be added later when sidethrust is determined? Bit tight under there.
Agree re wheels, started again. Our strip gets wet and is shared with sheep (see below)!
Rear hatch is for elevator connections, single pushrod from the servo under the wing, splits into two via an internal horn and axle to two external horns.
Watching with interest. Will ask the Sheepharmer (for it is he) if he'll do a build log.
BTC
Bruce Collinson10/01/2019 16:16:41
532 forum posts
Not off to a good start. The manual is for a different plane. Cymaz, please see my PM.
BTC
cymaz10/01/2019 16:53:33
avatar
9249 forum posts
1194 photos
I have the manual for a Surpass 90 surprise. So, will email PB tonight and see if they can sort it. Build on hold, until this is resolved.
Jeremy Harmer10/01/2019 17:14:31
3 forum posts
I have exact same problem with instruction manual Cymaz. Anyone know what a 'Surpass 90' is? I thought it was an engine.
I shall email a request for correct info to ProBuild too.
Jeremy Harmer10/01/2019 17:56:15
3 forum posts
Regarding the hatch underneath the tailplane, it would appear there are reinforcements/mountings for small flanged bearings to support a cross shaft and internal/external horns to connect two elevators to one servo similar to the example here.
cymaz10/01/2019 17:58:23
avatar
9249 forum posts
1194 photos
News Flash....!
A 20cc Evolution does NOT fit...no way.....no flippin way....angry 2. So now it’s buy a DLE20 ra. Hate spending money angry 2
Cheers Jeremy, might look into that. After the elevator pushrod shambles that my Wot4xl build went through, I try and stay clear of V rods to elevators.
Edited By cymaz on 10/01/2019 18:01:28
Bruce Collinson10/01/2019 18:41:08
532 forum posts
Cymaz,
Are you sure a DLE will fit, particularly the RA? Are you immune to 87 dB levels at your site? I don’t think a 20RA will use less space then your Evo. The carb’s at the rear too. Shall I ask JH to try to post a couple of pics of mine, as I lose the will to live every time I attempt to upload pics via this tablet.
BTC
cymaz10/01/2019 19:07:10
avatar
9249 forum posts
1194 photos
Posted by Bruce Collinson on 10/01/2019 18:41:08:
Cymaz,
BTC
Oh pictures please !!
Hi Jo and Peter
thank you for the interest in the infinity 90. we tested this model with a dle 20 and 20ra and works great but a dle 30 is a little large to fit into the cowl.
we would advise the dle 20ra
Best Regards
Andy Williams
Probuild Aircraft Ltd
Edited By cymaz on 10/01/2019 19:09:43
cymaz10/01/2019 20:59:46
avatar
9249 forum posts
1194 photos
Got THIS for the elevators
cymaz11/01/2019 18:13:44
avatar
9249 forum posts
1194 photos
I phoned PB today. The instructions marked Surpass 90....are correct! The addendums slipped in the pages are correct as well, so I’m told.
This weekend there won’t be a lot doing. I’ve got a club mate coming over Sunday and on Saturday Mrs C and I are off toThe Eden Project. There is a free locals pass this weekend for all living in PL30/31, it would be rude not to make the effort. And besides it’s the only time we can afford to go. Damn expensive for some poly tunnels in a hole in the ground if you ask me dont know
Bruce Collinson11/01/2019 19:09:44
532 forum posts
Cymaz,
Wasn’t the elevator linkage a standard part set supplied by Probuild?
The point where the exhaust pipe exits the back of the u/c plate area is totally different shape. Couldn’t see c of g, suggested throws etc. We are convening a Laser/ASP tank fitting exercise tomorrow morning as there are strong winds here oop North.
BTC
cymaz11/01/2019 19:27:04
avatar
9249 forum posts
1194 photos
There was a dowel rod for the elevator....no sign of the crank so that's why I got one. I have the page with CG and throws. I will post this soon for you. When I rang I double checked about these and where assured that the numbers was correct
cymaz11/01/2019 19:48:09
avatar
9249 forum posts
1194 photos
Jeremy, I can't see your photoembarrassed
Martyn K12/01/2019 12:15:08
avatar
5083 forum posts
3678 photos
Hi Cymaz
Is this the model? If so looks like really good value compared with the price of many other F3As
Martyn
cymaz12/01/2019 13:19:12
avatar
9249 forum posts
1194 photos
That’s the one ☝️. The rear hatch will be useful. Going to start on the plane and wings when I’m home
Please login to post a reply.
Latest Forum Posts
Support Our Partners
electricwingman 2017
Sussex Model Centre
Slec
CML
Sarik
Advertise With Us
Latest "For Sale" Ads
Q: The effects of Coronavirus
 Yes - for the first time
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
Magazine Locator
Find RCM&E!
