Forum sponsored by:
Forum sponsored by CML
Chilli Breeze from Sarik Plan, Electric Conversion.
All Topics | Latest Posts
Search for:  in Thread Title in
Stuart Quinn-Harvie 111/02/2019 15:56:13
avatar
108 forum posts
81 photos
Afternoon folks.
The plan, wood and power system have arrived, and I will be cracking on with it very shortly, starting with the fuselage because that's where I always start, and I am a middle aged man and therefore fear change, And because an on line retailer provided me with trailing edge stock that curves like a boomerang, so I will have to replace it.
I am using a PROPDRIVE v2 3542 1000KV rated at 47 amps with a 60 amp speed controller and 4s 2200mah batteries. I haven't decided on the propeller yet but am thinking something like 12x5. As per Nigel R's recommendation the FWall will be placed about an inch further forward, and I think I will work out a bottom mounted hatch for the battery.
One thing that I am thinking about is changing the undercart to a trike - partly because I like the way they look and partly because I have an unreasonable fear of nosing over. ( I have no idea either )
Aileron servos will be fitted in each wing for simplicity and because I like nice short linkages.
That seems about it, so time to clear the board and assemble the SLEC fuselage jig before another banana takes shape in the workshop.
Any suggestions, caveats or hoots of derisive laughter welcome.
Edited By Stuart Quinn-Harvie 1 on 11/02/2019 15:57:01
Edited By Stuart Quinn-Harvie 1 on 11/02/2019 15:57:39
Denis Watkins11/02/2019 16:06:48
3736 forum posts
178 photos
Maybe some snippets here Stuart **LINK**
Nigel R11/02/2019 16:27:16
avatar
2923 forum posts
470 photos
You'll struggle to get it to nose over. It sits low. It is long. The wheels are quite forward. And are also set wide. Ground handling is excellent.
12x5 is (in my opinion) way too much diameter for 4S, and not enough pitch and I think you will find it draws a monster current from that 1000kv motor - I'd suggest 10x6 or 10x7 and go from there.
As a comparison, I just finished an RM Aerobat, which is somewhat sleek although not quite as much so as the Chilli, it is just shy of 3-1/2lb, has a 10x6 on a 3536-910kv motor with 4S 2200mAh lipo, my wattmeter shows 450W and I get an 8 minute flight.
Might be worth planning ahead for motor mounting & cowl arrangement.
My larger Chilli, uses a 2-1/2" spinner. This means the nose ring can be (and indeed has been) opened up enough to get the motor in through the front. Four small notches provide just enough space to get the screwdriver at the mounting screws. Not sure if that approach would still work on the smaller size - what is the spinner, 2"? Going to be tight!
Watching with interest.
Frank Skilbeck11/02/2019 16:52:37
avatar
4422 forum posts
101 photos
Just ran the motor through ecalc with a 12x5 and 4s 2200 mah battery gives 730watts and 57 amps..............
An 11 x 5 drops it to 608 watts and 47 amps.
10 x 6, 540 watts and 40 amps
Nigel R11/02/2019 17:18:21
avatar
2923 forum posts
470 photos
^ I have a 3536 - 1050kv which showed 550W on a 9x6 !
ecalc always seems to come out a little conservative when I try it. At least, compared to the "just charged" numbers.
Stuart Quinn-Harvie 111/02/2019 17:33:09
avatar
108 forum posts
81 photos
Cheers folks: I will look into the prop issue a little more as I go on. some good looking suggestions there though ( I am still getting used to this new fangled electron-shunting) I will indeed have a planning session re the nose, and take note of what you say, Nigel re the undercart. I'll keep it simple
Stuart Quinn-Harvie 111/02/2019 17:33:10
avatar
108 forum posts
81 photos
Stuart Quinn-Harvie 117/02/2019 20:33:48
avatar
108 forum posts
81 photos
A slightly delayed start due to life the universe and everything, but tonight I got the SLEC jig together ( one of those jobs I had been meaning to get around to ) cut the root and tip templates and sandwiched some balsa together. I've not used the sandwich method before so decided to start with that - having a set of wing ribs always cheers me up.
I've been playing with a plan built Cardinal as well ( I have always had a terrible habit of doing more than one project at a time ) and that is up to the installation and covering stage.
I'll put up spme pictures when I have something to show
Stuart Quinn-Harvie 120/02/2019 00:04:13
avatar
108 forum posts
81 photos
I've actually started. I cut the ribs ( and decided I REALLY dislike the sandwich method - although alighning them all to the trailing edge may not have been the best ides - perhaps aligning them equally to the leading and trailing edges would be better. Either way it' done now but I am going to do it differently next time, just to be sure.
the plan calls for the TE and LE to be supported first, then the ribs, THEN the spars, but being an Olde Farte with some Fixed Ideas, I've decided to put the spars in first aligned to the TE then add the LE. I am not sure which way is better, but so far the wing is nice and true, so I am happy so far.
Having paid seventeen quid for the plan ( I think this is the first time I have built from a plan that wasn't free in a magazine, or from Outerzone, and only the third or fourth plan only build I have ever done) it felt odd chopping it up, but there we go, I suppose. Rather than covering it with cling film, I use double wide sticky tape and that keeps everything glue free and doesn't crumple or get in the way as much.
It's not the best build by a long way, but it's a start - and I am enjoying it.
Nigel R20/02/2019 15:22:26
avatar
2923 forum posts
470 photos
I can't stand the sandwich method either. All the edges come out at an angle and need dressing afterward, and I always ended up with lumps and flats shouldn't be there.
I like printed templates much better. They seem to take about the same amount of time to make a rib set. And it is more accurate when done.
Piers Bowlan20/02/2019 15:57:03
avatar
1801 forum posts
44 photos
Agree Nigel yes.
Stuart Quinn-Harvie 126/02/2019 12:07:17
avatar
108 forum posts
81 photos
Hi Nigel and Piers: Indeed - I think I'll be investing in some kind of rib/drawing software in future.
After some fettling I am here now - about two thirds of the way through the wing panels. In a spectacular case of having the instructions printed out next to me and ignoring them completely I put the root ribs on because of course I did. I really should have thought about it more but I decided at the time that I would just cut the ribs away where the dihedral braces would go, so that's what I am going to do. It'll be fine, I just shouldn't have been watching TV and building at the same time. My building will never be to the standards that some of the folks on here exhibit but it normally is good enough to get a well behaving aeroplane out of things. img_20190226_114335.jpg
Having gone back to look at the instructions again, I see that they mention spar webs - although none are shown on the plan - does anyone have any advice here? I am kind of leaning toward putting them in out of a belt and braces attitude.
Servo mounts will go on very soon - possibly this evening and I hope to start the fuselage tomorrow, using a jig for the first time.
Speaking of the fuselage, I will, as per Nigel's recommendation be moving the firewall forward and I am contemplating ways to lighten the fus a bit too. I was thinking balsa rather than ply doublers crossgrained to the sides, for a start, and 9g metal geared servos in the tail for the ele and rudder. ( just for ease of maintenance, if nothing else. )
And I need to start thinking about the battery hatch. Stuart Marsden's electric conversion thread is being very helpful, btw.
Undercart will be mounted on the fuselage rather than the wings so I will beef up the mounting area too.
Right, back to work.
Piers Bowlan26/02/2019 13:31:05
avatar
1801 forum posts
44 photos
Personally, yes, spar webs. Massive increase in strength for a modest increase in weight. Grain vertical of course. Servos in the tail, even nine gram ones, will require quite a bit of weight in the nose to counter-balance. Just as well that you are moving the motor bulkhead forward. yes
Looks great.
Nigel R26/02/2019 13:40:06
avatar
2923 forum posts
470 photos
Yes, definitely use spar webs. Weight, almost nothing, increased resistance to warp and bending, lots. It's not belt and braces, the webs simply complete the D box structure, without them it is only part formed.
I'd personally never use smaller than a HS225 on the tail surfaces on something this size, and HS81 for ailerons. Preferably in metal gear flavours. 9g are ok for park flyers that weigh 1/2lb.
Other opinions are available.
Piers Bowlan26/02/2019 14:01:17
avatar
1801 forum posts
44 photos
HS225 - good choice; cheap, powerful and reliable. HS85MGs in the wings perhaps.
kc26/02/2019 19:03:11
5924 forum posts
168 photos
I reckon a ply doubler will be even more important if you mount the u/c on the fuselage. Maybe reduce the height of the ply though, perhaps just draw a straight line from F1 to the end behind the wing - a long thin tapered triangle shaped doubler which would almost halve the ply and glue needed. Of course extend it to the new F1 if you move F1 forward. Would be sufficient for electric. A ply doubler usually means a plane stays resonably straight, intact and repairable after a crash or hard landing. Worth fitting.
Consider a torque rod u/c as used on many of Peter Millers recent models also Boddington designs etc.etc.
Stuart Quinn-Harvie 127/02/2019 08:11:26
avatar
108 forum posts
81 photos
Hi all, thanks for the advice - I feel like a noob again ( which, effectively I am as far as building goes, at least - the last plan or kit build I did was in er...2004 or thereabouts) Ply doubler going in then
And heftier servos.
Nigel R27/02/2019 10:39:40
avatar
2923 forum posts
470 photos
Well spotted kc, fuselage mounted U/C definitely favours a ply doubler, and I'd agree with tapering it. I'd draw a straight line from top of the firewall to a point about 1" above the wing TE though, just to give a bit of meat across the wing saddle.
Torque rod U/Cs are great shout too. They have a lot more "give" than a plate aluminium gear, and lighter too. Quite simple to bend up. I try to pattern the leg like a 3:4:5 triangle, that is, make the leg itself 5", bend it so that it drops 3" and projects outward 4". The exact dimensions will just need scaling appropriately, but this is kind of about Chilli size:
You just need a 1/8" ply plate on the fuselage underside. Several bits of 1/8" birch ply or 1/8" spruce go above the plate and hold the torque arms in place.
On a low winger I would stick the U/C on the wing though. You can get the wheels further apart and the whole thing is thus a bit more stable.
Stuart Quinn-Harvie 128/02/2019 10:36:57
avatar
108 forum posts
81 photos
That's what I was thinking, my first trainers had undercarts like that easy to make and very forgiving - our field is lumpier than a lumpy thing so this kind of undercart with 2 1/2 to three inch wheels should do nicely. point taken about wing mounted u/cs though and will be born in mind for the future.
kc28/02/2019 13:29:54
5924 forum posts
168 photos
If you angle the slots that take the vertical part the wire can be flat and not 'handed'. Angling is done so the wheels come under the LE or whatever suits the design. The flat wire parts are therefore useful for other models too - they outlast the model normally and also make the old model without u/c easier to store.
The slots in the ply need to be staggered by the thickness of the wire to allow the u/c legs to fit alongside each other. I always cut the slots in 1/8 birch ply slightly undersize and cover the slot with a slightly smaller piece of ply- total thickness is then 1/4. Then at final stage run an exact size drill through which gives a slop free fit. Easier than trying to drill an angled hole through 1/4 ply!
Please login to post a reply.
Magazine Locator
Find RCM&E!
Latest Forum Posts
Support Our Partners
Gliders Distribution
electricwingman 2017
Slec
CML
Addlestone Models
Pepe Aircraft
Wings & Wheels 2019
Cambridge Gliding Club
Sarik
Advertise With Us
Latest "For Sale" Ads
Does your club have a safety officer?
Q: Does your club have a safety officer, or is the emphasis on individual members to each be their own safety officer?
 Yes we have a SO
 No, it's down to everyone
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
