Forum sponsored by:
Forum sponsored by CML
104 inch B-17 Identification
All Topics | Latest Posts
Search for:  in Thread Title in
Chris Walby12/03/2019 19:19:18
avatar
915 forum posts
221 photos
Hi guys,
I am helping out another club member with a B17 that a late club member built and nearly finished.
I am after a set of plans and thought it was a design by Aerotech, but looking at these plans there are a number of things that are different, namely:
Now its possible the builder modified things, but I don’t think he did as my wing has working split flaps. Other differences are even more fundamental like:
  • My wings are two piece, the Aerotech looks one piece
  • My wings have two vertical tabs that go into the fuselage and bolt together
  • My wings look fully built rib/balsa sheet, the Aerotech look like foam core
  • The drawings show pins (into fuselage) and screws near the TE which mine does not have
Big question…any idea if there were any other B17 104 inch models available running 4 x SC52's.
There is of course a chance that he had it re-scaled but the ribs I can see are laser cut as they have ID number on them.
If any photos would help I can post
Any suggestions warmly welcomed as to where I can get a set of plans and a couple of cowls.
Thanks for your time
eflightray12/03/2019 20:00:58
avatar
560 forum posts
127 photos
Aerotech used to do a 1/12 (104" span) scale B-17 kit, but it was a while ago.
Martin Harris12/03/2019 20:02:13
avatar
8488 forum posts
212 photos
It was obtained from the USA if that's any help.  Mick E had quite a lot to do with this model - have you asked him?
Try searching for 12th scale or 103".
It was built from a (laser?) cut part kit.
Edited By Martin Harris on 12/03/2019 20:24:09
eflightray12/03/2019 20:03:16
avatar
560 forum posts
127 photos
Just spotted this thread -- Aerotech B-17
Chris Walby12/03/2019 20:23:49
avatar
915 forum posts
221 photos
Hi,
I obtained a set of Aerotech plans....see my OP as its not at all close to that....I suppose Brian might have changed the wing material, flaps, wing to fuselage mount and main spar design, but it would seem a lot of effort unless Aerotech made two versions with the same wingspan model?
Rib numbering is different, could have been a resized and laser cut, but then I don't know if he used the plastic parts on the fuselage. Two of the cowls are the right size!
Edited By Chris Walby on 12/03/2019 20:27:59
Martin Harris12/03/2019 20:30:40
avatar
8488 forum posts
212 photos
Aeropak B17?
Chris Walby12/03/2019 20:38:53
avatar
915 forum posts
221 photos
Martin, could be...not sure about spending $60 just to get a set of drawings... wink
Edited By Chris Walby on 12/03/2019 20:41:03
John Duncker13/03/2019 19:19:55
77 forum posts
7 photos
Keep posting here Chris.
I would love to know if it flies.
I helped out with some of the changes he made but I do not recall if he made the changes to a split wing, I know we did discuss this when he was in the planning stage and we both thought that split wing was the way to go purely to make it easier for him and Carol to handle.
I know we did look at the possibility of a Royal B 17 kit and I think I tried to steer him away from this as he had a tendancy to build heavy.
But there has been a lot of water under my keel since then and my memory may be playing tricks.
Chris Walby13/03/2019 20:37:33
avatar
915 forum posts
221 photos
John,
Thanks for the information as even the odd snippet of information is useful. Martin suggested I talk to Mick as he assisted Brian as well.
I was surprised at how light the wings felt with a pair of 52's in them compared with my IC Seagull Mosquito, 3kg compared to 2.7 kg and its 20 inch less wingspan. Although I don't know the fuselage might come out as it could be on the heavy side!
I can see the logic as the Aerotech looks a one piece wing and must be a real issue transporting it about at 104 inches if the had gone for that.
Can you remember when Brian started the B17?
We get Brian's Vulcan flying on special occasions and that has marginal power and high wing loading, but its just great watching it take up the sky as Dave hauls it around for another Farnborough pass!
As you can see hopefully there is not that much left to do in 11 weeks if I get a move on as the fuselage is apparently complete its just finish off the wings!
eflightray14/03/2019 13:21:01
avatar
560 forum posts
127 photos
Nice model the B-17
My scratch built, (no plans), 100" span, foam core wing covered in brown paper, the rest is balsa. Plug in wings, and horizontal stabs for easy transport.
Electric power. The video was shot when she still had brushed motors, Olympus belt drives, and Nimh cells. She was eventually upgraded to brushless and Lipo, and shaved 2Lbs of the weight.
Current flying weight is 10Lbs - 2oz, Still fly her occasionally.
Ray.
cymaz14/03/2019 17:15:46
avatar
8454 forum posts
1160 photos
This is any good ?
Chris Walby14/03/2019 21:49:28
avatar
915 forum posts
221 photos
Thanks cymaz, looking at some of their build photos it looks the closest so far although I am not to sure they would do a special 12th scale version with the cowls etc.
I'll see if Mick's about at the weekend...not likely to be much flying!
John Duncker15/03/2019 02:05:34
77 forum posts
7 photos
2005 would be about right for a start date. When I last saw him at his workshop he had both wings complete and we did a trial fit of the joiners and that would be the summer of 2007.
I am glad the Vulcan is still flying. It was marginal off grass but once airborne flew very nicely.
Did Mick get his Hunter flying? I am blown away by the performance of these lecky fans.
Chris Walby15/03/2019 06:49:13
avatar
915 forum posts
221 photos
JD, Thanks for the info, hadn't realised he had been at it that long with the B17, still have some time with my DC3 then! The Vulcan I have (Brian's) is twin electric pusher as he had a IC prior to that. Marginal is an understatement as it takes 20 yards of bungee at over 50 lbs of pull to get it into the sky and about four major rebuilds to iron out the issues.
I understand the Hunter went in on its maiden, not sure the cause as I was not there.
eflightray15/03/2019 15:37:57
avatar
560 forum posts
127 photos
Build light. they fly much better.
Sorry the video is so poor, I forgot to check and clean the lens.
82" span, 8Lb - 15oz flying, under 600 watts total.
Ray.
Chris Walby17/03/2019 21:52:59
avatar
915 forum posts
221 photos
Progress is almost completely good news, regarding missing bits etc.
A club member had the missing cowls and better still Brian has detailed the Starboard inner cowl (no3) so that makes life easier.
I have obtained the glass sheet to finish + 2 of the 4 silencers.
Made a wheel spindle and fitted some 100mm wheels
Dave found the ailerons and they are covered so that's good
Found a photo of the fuselage from a couple of years back (I haven't seen it since) but it looked good then.
20a%20memphis%20belle%20(boeing%20b17)%20-%20brian%20hilliard%20(in%20progress%20and%20best%20in%20show)[1].jpg
Only sticking point at the moment is getting hold of four sets of Robart U/C air line quick connectors (white) that seem to be out of stock in the UK.
If anyone has any please PM and I'll arrange suitable payment
Chris Walby19/03/2019 22:49:07
avatar
915 forum posts
221 photos
Getting ahead of myself as I don't have the fuselage, but was wondering what people suggest as RX set up for something this size/complexity
It will have dual battery, dual switches or switch with fail over.
  1. Throttle
  2. Rudder
  3. Ailerons
  4. Elevators
  5. Flaps
  6. Gear - air
Now my mosquito I have engines and gear (mech with servos) set up on separate channels as it makes life easy adjusting each if necessary.
So could go for as I have a 8 channel TX (DX8 g2)
  1. Throttle (engines 1 and 4)
  2. Throttle (engines 2 and 3)
  3. Rudder
  4. Ailerons
  5. Elevators
  6. Flaps
  7. Gear - air
Now someone mentioned using two 6 channel RX's, but I can't see the benefit unless to use two TX's (and have a helper).
Ideas anyone?
Edited By Chris Walby on 19/03/2019 22:50:25
Jon - Laser Engines20/03/2019 08:44:42
4612 forum posts
172 photos
Keep it simple. The more complicated you make it the more likely something is to go wrong. Although the model is big its not heavily loaded and will basically just float about. it is only as complicated as you make it.
I had an ESM Hercules of 100 inch and it had one rx, one battery (a good one), one switch and then y leads to the dual elevator, aileron, flap servos. Throttles were done with y leads into y leads.
Each throttle was as close to mechanically identical as possible but i didnt loose sleep over it. On a 4 engine model the effects of one engine running slow/fast are not as big as on a twin. Indeed i lost one on the herc once and didnt even notice until i did a flyby.
In the instructions for the herc it recommended to set up the throttles on two channels so the inner and outer engines could be controlled individually. The theory was that if one engine stopped you would kill its best mate. This struck me as daft as you are turning the loss of one engine into the loss of two. If another drops you are really screwed! The only time i would consider killing the engines on a 4 engine model it would be if i lost two engines on one side. I would try and keep it flying, but i would be prepared to cut it.
If you do use dual rx's make sure the throttles are on a different rx to the rudder. The reason for this is that if you throttle rx drops and you have to wait for it to run out of fuel you can guarantee one engine will keep going longer than all of the others. In this case you will need rudder control to keep it pointing the right way. Equally, if you have throttle control rudder is less of a concern.
Dickw20/03/2019 13:26:21
avatar
435 forum posts
76 photos
Posted by Chris Walby on 19/03/2019 22:49:07:
  1. Throttle
  2. Rudder
  3. Ailerons
  4. Elevators
  5. Flaps
  6. Gear - air
  3. Rudder
  4. Ailerons
  5. Elevators
  6. Flaps
  7. Gear - air
Ideas anyone?
I am guessing they may be doing that to gain some redundancy using two 2 Rx each with its own power supply. e.g :-
throttles 1 and 4 on 1. Rx1, with 2 and 3 on 1. Rx 2
Rudder on 2. Rx1
Split the ailerons between 3. Rx1 and 3. Rx 2
Elevators – use two servos on 4. Rx1 and 4. Rx2
Flaps 5. Rx2
Gear 6. Rx1 or Rx2
If either Rx fails you still have throttle on 2 engines, plus one half of ailerons, and one half of elevator. Rudder, gear, or flaps, either work or don’t depending on which Rx fails.
Dick
Chris Walby20/03/2019 13:29:28
avatar
915 forum posts
221 photos
Jon,
I see your logic and agree with keeping it simple. The Dual Ace has two batteries and a single fail over switch, the mossie single battery and no switch (as its easy to open the canopy to connect) and the hurricane single battery. All only have one RX.
Sounds like one good size RX battery with switch (of darn good size), one RX and keep it simple.
Struggling to see the benefit of only two throttle channels for setting up as either 4 channels would help (but don't have that many free) or a Y and a Y as a little unbalance does not seem to be an issue.
I'll knock a drawing up see how things go down.
PS Quite like the Hurricane power box arrangement as it has a fail safe switch.
Please login to post a reply.
Magazine Locator
Find RCM&E!
Latest Forum Posts
Support Our Partners
Wings & Wheels 2019
Gliders Distribution
Revoc
Motion RC
electricwingman 2017
Pepe Aircraft
Slec
CML
Advertise With Us
Sarik
Latest "For Sale" Ads
Does your club have a safety officer?
Q: Does your club have a safety officer, or is the emphasis on individual members to each be their own safety officer?
 Yes we have a SO
 No, it's down to everyone
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
