Forum sponsored by:
Forum sponsored by CML
Setting up for Flaps
No Flap operationApart from Flaps
All Topics | Latest Posts
Search for:  in Thread Title in
Geoff Daunt26/03/2019 18:50:18
96 forum posts
l have acquired a Pelican Grace Glider which l am trying to set up with a new Motor and Prop.
My Tx is a JR DSX9 . This only supports DSM2 so l am using Spectrum Rx which support both 2 & DSMX.
The Glider supports 7 Channels 2x Ail, 2xFlap, Elev. Rudd. Motor.
l am following the JR Inst. Manual for a 6 Chanel set up , ie for everything other than motor.
l am using a Spectrum AR10000Rx ie 10 channel
Following the Manuel the Rx is plugged as follows
Left Ail into ... throttle on Rx
Left flap.... Aux1
Right Ail. ...Aileron
Right Flap.... Gear
Rudder ..... Rudder
Elevator....Elevator
The Esc is plugged into Aux2 for Motor and l have allocated this to left side flap lever on side of Tx.
Apart from Flaps everything is working correctly including motor.
When l switch on the Flaps default to the full down position, about 80 degrees.
The Flaps should operate on the Spoiler/Throttle stick but nothing happens.
l have tried the Servo reverse on Flap on the menu but again nothing happens.
Following the Menu and using Sub trim the Flaps will move but that is it.
l have spent hours trying to get the Flaps to work on Spoiler but to no avail.
it is driving me crazy.
Any help greatly appreciated..... otherwise l cannot fly 😂😂😂
Martin McIntosh26/03/2019 20:43:56
avatar
2833 forum posts
1050 photos
If you follow the JR manual you will never get them to work, it is rubbish. Google a full house glider set up and you should find a guide as to how it should really be done, as I had to. No idea where my instructions are now but could guide you through it if you draw a blank. Mine uses a normal throttle stick and the mode switch for launch, normal flight and crow. Quite easy to use although it would be nice to be able to disable the throttle then use the stick for variable crow braking.
Denis Watkins27/03/2019 07:47:59
3681 forum posts
173 photos
Geoff, check this set up
**LINK**
Gary Binnie27/03/2019 11:23:30
avatar
515 forum posts
34 photos
The problem might be in the 'DeviceSEL menu.
This is my menu for an F5J glider, I have the motor on a switch only (labelled T.hold.Mix on theTx), crow braking enabled in all flight modes on the left stick (Mode 2).
Prog Mix 4 is MOTO > AUX2 (Pos 0 = -125% Pos 1 = 125%)
I have other mixes in there but they are just elevator compensation, ailerons up for crow and snap flap (elevator/flap mix).
I moved to a DSX12 which has the same wacky glider channel assignments, it can do a six servo wing but it's mighty awkward. I gave up and moved to Jeti where you tell the transmitter what channel you want things on.
Here's the screenshot.
FlyinBrian27/03/2019 11:49:19
512 forum posts
Take a look here, works great on my MPX Herron
LINK
Geoff Daunt27/03/2019 17:08:31
96 forum posts
Many thanks for replies. I am not that bothered, at the moment , to have all singing and dancing Mixes for launch ,speed and land etc Quite happy with the basics of simple flap operation, maybe mixed with elevator, for landing.
So decided to have a look atGary Binnie’s advice first if indeed l was wrong in Device Select, which would be the simplest solution
l copied your set up int my Tx.
Nothing changed on my Flaps, ie only defaulted to full down and no lever or switch has any effect on Flap. But l did lose motor operation. I have returned to my original setting and have motor operation back
As mentioned in first Post l have esc into Aux2 and my assigned switch is Aux3lever.
I have Aux3,4,5 free so could use any of those if necessary to power the electric motor, if l need Aux2 free.
Gary could you confirm if your various Servo inputs are into same Rx points as mine ,as indicated in my original post,
if yours are different could you kindly tell me so we are doing like for like and l can take it from there
Many thanks
Denis Watkins27/03/2019 17:17:57
3681 forum posts
173 photos
Why not Left Flap, and Right Flap in Aux 1 on a Y lead, as both surfaces go up or down at the same time to operarate.
Installing flaps initially has servos fitted that each drives the same way.
Martin McIntosh27/03/2019 17:30:44
avatar
2833 forum posts
1050 photos
You need the settings for your DSX9, nothing else. As I said above, just google it.
John Lee27/03/2019 17:59:02
633 forum posts
47 photos
Geoff I also struggled to get a satisfactory setup with a DSX9, like Gary I also tried with a DSX12 but in the end admitted defeat & moved to Jeti. That said I did find it much easier with a Spektrum DX9 than the JR DSX9, software rapidly developed soon after JR's DSM2 radios came to market.
However I was more or less able to get a limited glider setup working on the DSX9 with the help of the DVD 'Radio Clinic for Sailplanes' produced around 2008 for the JR XP9303 which has the same programming as the DSX9. If you PM me your address I'll send you the DVD with my compliments, its 1hour 50mins may well help clarify some of the many quirks in the software.
Geoff Daunt27/03/2019 19:08:38
96 forum posts
Hi John. Sorry to be stupid but what is PM my Address and how do l do it !🤔. Thank you for your interest and offer.
Geoff.
Gary Binnie27/03/2019 19:19:16
avatar
515 forum posts
34 photos
I'm afraid all my electro gliders are on Jeti now but I'm fairly sure the channel assignment was by the JR manual.
I know at one stage I used the Aux 4 port but can't remember why, I also had an intermittent right flap problem (sometimes it moved, other times it froze), spent ages looking at the wiring but in the end it was down to a conflicting mix.
There is a function on the DSX9 (and others) which changes the throttle stick control between throttle and crow brake depending on the flight mode, I think it's called 'moto hold' but I never dabbled with that.
On Y leads, the higher performance gliders can have their flaps move up (reflex) for a high speed/low drag aerofoil. This handily also means that the flaps can work opposite each other for extra roll control, in that case the flaps can't easily share a channel. The independent sub trim function for each flap would be lost though mechanical adjustment would still be available through the pushrod clevis.
Cheers
Gary
John Lee27/03/2019 22:50:55
633 forum posts
47 photos
Geoff, PM = send me a Private Message (so as not to reveal your address to the whole world). Just click on my name in this post & scroll down, you will see an option "Send me a message" and click on that. Your message will be sent to my inbox on this site & I will also get an email from model flying.co.uk telling me that the message is waiting for me. I can then reply via the site or if you include your email address in the message I can respond directly. I'll send you a PM now with this info copied & pasted.
John
Geoff Daunt28/03/2019 10:29:06
96 forum posts
Hi Martin, thanks for input. Just working my way through the various suggested options.
Pretty Happy my Rx set up ,as set out in original Blog ,is good.This seems to be the same for the Spectrum DX Rx’s which makes sense since we both operate on Spectrum technology.
looking at various Dx set up blogs /U tube videos the problem l have is that the Screen system and set up program
method is very different ,so l cannot follow that program method.
The more modern DX system looks so much easier to use !!!
It seems obvious to me l am just missing one simple matter to get the Flaps working in the Tx set up but at the moment l still cannot find it.
will persevere.
John Lee28/03/2019 11:20:41
633 forum posts
47 photos
Geoff try this on a new fresh model memory:
Select Model type Glider.
Then look at the Monitor screen. Move the throttle stick & I think you will find that it operates Aux2 output.
As you have allocated Aux2 to the left lever in your model setup that overrides the throttle stick which is left with nothing to do, hence no flaps. I think you will need to go back & allocate the left lever to Aux 3, 4 or 5 & use that as the motor control, freeing up Aux 2 for the throttle stick/flaps. I don't think you can just reallocate the throttle stick on the JR DSX software.
Hope that helps, it's from memory as I no longer have my DSX9 so apologies if I've got it wrong.
The DVD is on its way to you.
Steve Houghton 128/03/2019 15:00:45
avatar
1880 forum posts
128 photos
I have no idea about the JR set up as I fly with Hitec. I have a Multiplex Heron, with all the bells and whistles, but I set up motor & flaps on flight conditions with both operating on the throttle stick but switch operated. So I flick the switch one way and the stick operates the motor. When I want to land I flick the other way and the flaps work but not the motor. This does mean my flaps stick does work in the opposite direction but I can live with that.
Martin McIntosh28/03/2019 18:14:00
avatar
2833 forum posts
1050 photos
Hi Geoff, I have tried to photograph the relevant bits from my DSX9 but the Mk1 having no backlight made it difficult. This is for my Organic which uses a single central flap servo and a V tail but these bits are easily changed. Watch out for the left hand lever since it will operate flaps and cannot be disabled.
Sorry, a couple are duplicated but could not get rid of them.
Geoff Daunt29/03/2019 18:32:31
96 forum posts
Just to bring this blog to a conclusion.
Many many thanks to all who responded.
l have certainly learnt a lot about programming following all the links.!
A particular thanks to John Lee for the video which is very informative.
The prize however goes to Flyin Brian who sent me a link for a set up.
it was an easy written Instruction sheet dealing with a full 7 house Glider set up for the JR. and best of all .......it works 👌👌.
The Power of such Forums is amazing
Thanks again to everyone
Geoff , A happy Glider boy and looking foreword to maiden flight.
Martin McIntosh29/03/2019 19:45:41
avatar
2833 forum posts
1050 photos
Best of luck with the maiden, glad that we were of help.
Geoff Daunt01/04/2019 19:10:56
96 forum posts
Just a follow up.
Does anyone know who manufactured the Pelican Grace 2.7m Glider.
l have done a Cof G Calc, which comes out at 62 mm from LE on a cord of 230 mm, so about 27%.
Will need a fair bit of Pb to balance so just wondering if anyone has this Glider, and could tell me the Manufacturer figure for C of G.
Otherwise would you more experienced Glider Guys think 27% about right.
many thanks
John Lee01/04/2019 22:15:48
633 forum posts
47 photos
Glad you got the radio sorted Geoff.
The manufacturer of the Grace was RCM Pelikán in the Czech Republic. I think it may be worth starting a new thread in the Gliding section with the model name in the title, as this thread is indexed under 'Spektrum' many glider guiders will pass it by.
Please login to post a reply.
Magazine Locator
Find RCM&E!
Latest Forum Posts
Support Our Partners
Motion RC
electricwingman 2017
Pepe Aircraft
Wings & Wheels 2019
CML
Slec
Gliders Distribution
Revoc
Sarik
Advertise With Us
Latest "For Sale" Ads
Does your club have a safety officer?
Q: Does your club have a safety officer, or is the emphasis on individual members to each be their own safety officer?
 Yes we have a SO
 No, it's down to everyone
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
