Forum sponsored by:
Forum sponsored by CML
wire rigging
Hobbyking Flybaby
All Topics | Latest Posts
Search for:  in Thread Title in
Den Moran20/04/2019 03:51:07
avatar
141 forum posts
18 photos
Hi, everyone,
I'm rebuilding the wing support system for a Hobbyking Flybaby (44" w/s), and need to make up the wire support system. The system leads upwards from the axle ends to two bolts through the wing, and these bolts feed wire back to the single fuselage point above the wing.
My problem is sourcing fittings that will carry the wire, (sourcing) the wire itself, and secure it to the fixing points. I know I could make them, but as there are twelve of them (three under/three on top of each wing) I'm hoping they are a manufactured item. The bolt size through the wing is 4 mm dia.. The upper fuselage point is secured by a self-tapper (although I'll probably bolt this with 4mm nylon bolts) .
I don't even know what these fittings are called! Help!
Thanks, everyone, Den, Swansea
Percy Verance20/04/2019 07:05:46
avatar
8109 forum posts
155 photos
Hi Den
I'd have a look at what Mick Reeves has. He may have something ......
Model Boat specialits are another possibility. Quite often the fittings for model boats have their uses for us. I'd try Cornwall Model Boats for starters, but there are quite a few other model marine specialists too. The model boat side of the hobby doesn't appear to have suffered too much from the ravages of Hobbykingitis yet.........
Edited By Percy Verance on 20/04/2019 07:07:24
Don Fry20/04/2019 07:07:35
avatar
3726 forum posts
42 photos
Having looked at a photo of one of these, the rigging is non functional, so dressmakers cotton sheathed elastic will do for the "wire". I can't think of much commercial stuff available, except some of the fittings used for "closed loop" or "pull pull" control systems. Be easier to make your own, as a small model like that will not be happy straddled with a load of heavy units designed for load bearing in much heavier aircraft.
Denis Watkins20/04/2019 07:07:50
3736 forum posts
178 photos
Here, at Modelfixings too Den,
**LINK**
Peter Miller20/04/2019 08:23:44
avatar
10011 forum posts
1177 photos
10 articles
SOmetimes one can find proper turnbuckles on EBay and other places.
Controlline wire makes excellent rigging wire but as others have said if the model does not actaully need rigging wire shirring elastic from any haberdashers works real well and does not need tensioners
Andrew Ray20/04/2019 09:24:35
avatar
699 forum posts
19 photos
As Don and Peter say if it is non functional or something like this steel fishing wire (but in a smaller quantity) either from your local fishing tackle shop or online. Buy crimps or make them from copper or brass tube. For the brackets use some thin brass or tin.
Den Moran21/04/2019 06:32:29
avatar
141 forum posts
18 photos
Thanks, everyone. As the rigging is functional for this particular aircraft,, a necessary part of the wing support system, I'll go with the fishing wire et al, and use soldered crimps.
It's the brackets that are key to avoiding all that drilling and shaping. My hands aren't up to too much of that these days! Cheers, Den
Andrew Ray21/04/2019 08:15:12
avatar
699 forum posts
19 photos
Den, you may not be able to solder fishing wire, it is usually coated. I use wire cutters on the crimp and enough pressure to do the job, across the tube and usually in 2 or 3 places.
Simon Chaddock21/04/2019 08:32:31
avatar
5405 forum posts
2824 photos
If the rigging is fully functional you really do need turnbuckles to be able to accurately balance the tension as any discrepancy between the leading and trailing wire will effect the wing incidence out towards the tip, particularly as the load varies.
Don Fry21/04/2019 11:03:01
avatar
3726 forum posts
42 photos
Sorry Den, I would never have thought a model that size would use functional rigging. An alternative to turnbuckles is a closed loop attachment (m2 thread one end, hole to attach wire/Dacron on the other), to a m2 clevis. I thin
Doc Marten21/04/2019 11:17:10
353 forum posts
4 photos
Fishing trace is good but I doubt it will solder as it's usually stainless steel so you'll need to crimp it OR (like in the old days of Pike fishing) using the nylon coated trace wire you could twist it then superglue it or melt the coating into a homogenus join.
Andrew Ray21/04/2019 11:28:15
avatar
699 forum posts
19 photos
Simon, sorry but I don't agree, I have Duncan Hutson's prototype electric SE5a, built by Duncan himself. It is 50 something inch wingspan, the rigging is most definitely functional, it is not fitted with turnbuckles and uses fishing trace that is crimped. It flies well and any slight difference in the rigging of the wires is not noticeable. If it's good enough for Duncan it's good enough for me...except I would most likely use turnbuckles on something larger.
Martin Harris21/04/2019 11:36:17
avatar
8669 forum posts
214 photos
If you use the crimped tube solution, we've found that an additional loop passed back through the crimp so that there are 3 wires in the tube means that the wires are forced into close contact and are far less likely to slip than a simple loop relying on the tube to wire point contact.
Doc Marten21/04/2019 18:29:55
353 forum posts
4 photos
Posted by Martin Harris on 21/04/2019 11:36:17:
Top tip this and again used extensively in Angling by any decent fisherman.
Den Moran22/04/2019 08:49:39
avatar
141 forum posts
18 photos
I agree about the 'top tip'!
As the four 'v's' come to single points, I've decided just to tension using the 'Spanish cramping' method, i.e. twisting, to take up slack, as I don't want/need the wires bow tight.
As usual, a really helpful response from everybody, cheerio, Den, Swansea.
Manish Chandrayan22/04/2019 09:30:58
576 forum posts
65 photos
If in need of turnbuckles look up here. Available from M1.2 to M3 thread size, different lengths and with loop or slot ends
Edited By Manish Chandrayan on 22/04/2019 09:31:10
Den Moran29/04/2019 09:54:58
avatar
141 forum posts
18 photos
Thanks, Manish, but turnbuckles are a bit too weighty for this aircraft. I looked up the fishing supplies, and they have 'figure of eight' flat pieces, which, if I bend them slightly, will be ideal. Thanks every one, Den.
Please login to post a reply.
Magazine Locator
Find RCM&E!
Latest Forum Posts
Support Our Partners
Addlestone Models
Pepe Aircraft
Gliders Distribution
electricwingman 2017
Wings & Wheels 2019
CML
Cambridge Gliding Club
Slec
Sarik
Advertise With Us
Latest "For Sale" Ads
Does your club have a safety officer?
Q: Does your club have a safety officer, or is the emphasis on individual members to each be their own safety officer?
 Yes we have a SO
 No, it's down to everyone
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
