Forum sponsored by:
Forum sponsored by CML
Hitec Flash 8 Battery Life
All Topics | Latest Posts
Search for:  in Thread Title in
RC Plane Flyer11/07/2019 07:22:41
670 forum posts
19 photos
Hi all Hitec users. Having had to upgrade to Flash 8 after trouble free Flash 7 which had a unfortunate accident I am now troubled with short battery span. I estimate I am getting 45 mins flight times with different models where the 7 lasted a lot longer. I have the correct charger for the 8's battery LiFe 6.6v 1400Mah and shows 6.7v at full charge r ( the 7 was on 2000Mah eneloops ) after some 6 ic flights I am seeing 6.4v and this then drops rapidly over next two flights. I am searching for a new or replacement battery pack but nothing showing up as yet, so come here for any experience, advice
Frank Skilbeck11/07/2019 08:11:35
avatar
4554 forum posts
101 photos
A full charged 2s liFe battery should be 7.2v, can you charge the battery out of the Tx and check the fully charged voltage.
Glenn Stevenson11/07/2019 08:37:49
38 forum posts
3 photos
Hi, check in the management settings that the battery is set to Life.
Maybe thats wrong
Glenn
RC Plane Flyer11/07/2019 08:57:51
670 forum posts
19 photos
Hi respondents. I do charge the battery out of the TX but only shows 6.7 v on screen maybe need to do further checks on charger settings. The Tx is factory settings to Life battery and that's why I get low battery warning
Thanks for replies so far
iqon11/07/2019 09:27:15
avatar
1468 forum posts
239 photos
Mine showing 6.7v, never seen low battery warning. Lasts ages
Glenn Stevenson11/07/2019 11:07:05
38 forum posts
3 photos
I charge mine in the tx, stays charged for ages
I usually top up after a days flying though, just in case
Shame the beeper isnt louder though.
Glenn
RC Plane Flyer11/07/2019 11:57:27
670 forum posts
19 photos
Hi Iqon & Glenn just out of interest which charge system are you using to charge the Life battery.
Multi purpose charger or the Hitec charger
I have reduced the backlite timer down to 20 secs from 30 secs and not using the dc output for anything
contrast down to 30%
Just sent an e mail to service dept in America see what happens
Glenn Stevenson11/07/2019 12:02:21
38 forum posts
3 photos
I use the charger it came with, not turned backlight down or contrast. Voltage stays at 6.7 volts as long as I need.
Try another battery.
Glenn
RC Plane Flyer11/07/2019 12:13:50
670 forum posts
19 photos
Hi Glenn thats the problem with another battery Hens teeth is what i am looking for until early august
Had a look in the battery bay and not much else will fit in
Glenn Stevenson11/07/2019 12:34:54
38 forum posts
3 photos
Hobbyking sell a 2100 life 2 cell transmitter pack that I use for receiver in planes that could be used if a bit of the tx case was trimmed a bit, a seller on ebay has hitec batteries for £30 but postage from germany is £14.30
Glenn
Glenn Stevenson11/07/2019 12:49:50
38 forum posts
3 photos
Have a look at this, it should fit
**LINK**
Glenn
iqon11/07/2019 12:50:45
avatar
1468 forum posts
239 photos
Posted by RC Plane Flyer on 11/07/2019 11:57:27:
Hitec charger that came with TX.
RC Plane Flyer11/07/2019 13:13:01
670 forum posts
19 photos
Hi Glenn did have a look at that earlier but did not double check battery chamber just checked and it should be a goer. Will wait to see if Hitec America get back to me.
alan p11/07/2019 14:43:51
230 forum posts
3 photos
Hi Glenn
Just charged tx battery on multi charger after discharging, showed full charge 7.0. back in tx screen showed 6.9.
Mine usually shows min 6.8 using supplied charger, and holds charge well, just make sure if it needs a top up if required.
John Tee11/07/2019 14:49:55
805 forum posts
65 photos
As a coincidence I have just bought one of these Tx's and it didn't work when I turned it on. The charger (Hitec supplied) was giving out 9 volts, the battery 0 volts. Charged the battery for the stated 8 hours and with all the playing about I have done with various settings and model setup's still shows 6.7 volts. Was a bit concerned at the lack of volts but seems to be holding up now. Time will tell. Never used Life batts. before.
John
RC Plane Flyer13/07/2019 09:07:52
670 forum posts
19 photos
Quick up date or is it a bump? America did not provide an answer and directed me to English agent still waiting for a reply from them. Looking at the option to get a Hitec charger that's another hens teeth problem. Looked at my current charging regieme and the charger auto shuts down after 2 hrs . So after mods to that and a charge for 4 hours I could see over 400 MaH input and the battery on screen showing 6.8 v.
Looks like I may be getting there
RC Plane Flyer15/07/2019 19:27:45
670 forum posts
19 photos
Last update for now I am led to believe that the Tx has an inbuilt Life charging PCB installed and that it only needs a 9/12 volt dc supply so its left to chance how many MaH go into the battery. I have had some responce from two suppliers re an alternative power pack supply but no responce from English Agent so I am going to charge my battery on a modern charger so I can see how many MaH have been input . I have seen over my last two charges over 600 MaH in put and a cut of voltage 7.2 v. So pen an paper in the Tx box to jot down flight times and see how we go from there
Happy Flying to all
robert chamberlain18/07/2019 08:54:58
134 forum posts
I have a Hitec Optima 6 Sport which has a low trans voltage warning but only for NiCad and NiMh. To use a LiFe I need to program it to accept this. The instructions say I need some kind of equipment, possibly to go through a computer. I can not find any reference to this anywhere. Does anyone know about this?---Thanks--Bob
RC Plane Flyer18/07/2019 15:25:36
670 forum posts
19 photos
Hi Bob. It's a long time since my Optic 6 but I am unable to remember if I every saw Life batteries being mentioned. Maybe à call to something like Airtekk Hobbies or Steve Webb to chat with someone. It sounds like an on line update maybe required Good Luck
Denis Watkins18/07/2019 16:12:40
4007 forum posts
73 photos
Do you know Bob, a good Nimh will last you years
You will have no concerns about programming your tranny
And your consumption is around 300mah, 300 milliamps in an hour
Overlander always served me well
Please login to post a reply.
Magazine Locator
Find RCM&E!
Latest Forum Posts
Support Our Partners
Slec
Gliders Distribution
electricwingman 2017
CML
Cambridge Gliding Club
Pepe Aircraft
Wings & Wheels 2019
Advertise With Us
Sarik
Latest "For Sale" Ads
 Yes
 No
 Sometimes
 Rarely
Latest Reviews
Digital Back Issues
RCM&E Digital Back Issues
Contact us
Contact us
